Looking for a No AIR Cat
Old Aug 27, 2001 | 09:26 PM
lostangel's Avatar
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
Does anyone make a Cat that does'nt have the AIR pipe? Has anyone got one?
I've already removed the AIR pump and other gobbely-gook.
86 Z28
305TPI
Stock, but with potential!
Old Aug 28, 2001 | 12:34 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Just weld the air tube on the new or used cat closed.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old Aug 28, 2001 | 12:01 PM
custman87T/A's Avatar
The CATCO that I have on my car had the air tube plugged when I bought it and I left it that way. No leaks and I don't have to worry about the air parts that were removed on my car.
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old Aug 28, 2001 | 02:36 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If I understand it correctly, fourth gen cars have 3-way cats with no AIR tube.
Old Sep 4, 2001 | 12:55 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I got a Dynomax 2-way 3" cat and it had no air tube.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 4, 2001 | 07:49 PM
98_1LE's Avatar
<font face="Verdana, Arial" size="2">Originally posted by afgun:
If I understand it correctly, fourth gen cars have 3-way cats with no AIR tube.</font>
True. Try http://www.cnlperformance.com/cats.html Thats what I am going with.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 7, 2015 09:11 AM
