what would be the best exhaust setup for;.....
Old Sep 28, 2001 | 03:17 PM
jeremyd19's Avatar
a 91 rs 305... i would like to know opinions on a whole setup from the headers all the way bacn.. info would be greatly appriciated.
Old Sep 28, 2001 | 07:43 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
How much are you willing to spend?
A setup like mine can get pricey though. But I absolutely LOVE the sound it makes
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Sep 28, 2001 | 08:19 PM
jeremyd19's Avatar
i just ordered a hooker super comp cat back system.. so what would i want to have with it. headers (type) and what kinda cat or no cat at all? by the way its a TBI
Old Sep 28, 2001 | 11:51 PM
Pukka's Avatar
Take the time and research the archives on this topic. There are some pretty good points of view.
Personally, I chose SLP Headers because of better workmanship. I got the 1 3/4 inch tubes because if I decide to swap in a bigger engine my exhaust won't be a restriction.
Cat converters are a must if you live where there is emissions testing. And in many places it is illegal to run straight pipes. However some people just run a straight pipe through a hollowed out cat to pass a visual check.
Like I said before, this option is pricey. The headers with necessary installation parts alone will set you back about $500. Add more $$ for ceramic coating and even more $$$ for labor charges.
Old Sep 29, 2001 | 10:16 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I recently replaced the entire exhaust system in my 92 RS 350(was 305).I, too chose the SLP headers, but in 1-5/8" Primaries,since it's a TBI-mostly torque motor.They're well made and fit well, too.They are expensive , though.
I also got a Flowmaster American Thunder Cat-Back system,Part#17234 for stock cat,
Part#17133 with 3" Cat.I like the sound.Not really noisy, but very low tone,and tinney.
Also figured I might as well put in a bigger cat, so added 3" Slip-Fit cat from Catco (not the best brand, from what I've heard).
All together about $1000+ the cost of having it welded up after I got it all on.Also using embossed copper gaskets at the heads (another $45), so I don't have to chase exhaust leaks.
Ordered everything from Summit.Came in 2 days!
-Rich-
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
snakeshooter
Sep 7, 2015 11:13 AM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
