Need pipe, where is it???
Old Mar 7, 2003 | 05:59 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
I finally got a test tube custom bent to go from the collector on my TES headers to where the stock exhaust would bolt to the back of the cat. But, I don't have the stock exhaust. I have the hooker exhaust, minus the tube that connects the muffler to the cat. Any one know where I can get just this pipe? It has to be 3", preferably mendel bent. if any one can help, I would be very appreciative. Thanks all,
Old Mar 7, 2003 | 11:06 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Dynomax sells the 3" intermediate pipe as I understand it. I'm guessing the cat end is slip-fit, although I haven't seen it. If you have a mismatch with the flange on your test tube, you could just cut the flange off and weld them together. Hope this helps...
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
