What Header Brand fits the best with no problems?
Old Feb 20, 2003 | 05:37 PM
KiLLJ0Y
Guest
Posts: n/a
car is a 92 305 tbi...
i really really really do not want to cut,grind,wedge, fabricate, or anything to make these fit. i'm not a moron when it comes to cars, and i have installed headers on a 93 TBI truck and my 86 IROC. i currently have a pair of Flow-Techs in my Garage but i need to stay smog-legal in CA.
so what are the lest problematic headers to intsall?
Eddlecrock?
SL(overpriced)P?
Hook(everyone has them)er?
Hed(dont know enough about them)man?
David Fisher
Orange CA
Old Feb 20, 2003 | 06:54 PM
steve8586iroc's Avatar
If the ones on the IROC fit good then get those. Hooker, Hedman, SLP, Edelbrock all make good smog headers.
Steve
Old Feb 20, 2003 | 09:18 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
How much for those Flowtechs?
Old Feb 20, 2003 | 10:47 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I have hedman w/ air tubes they were not too bad to install they will also fit angle plug heads if you ever decide to put a set on. I am happy with them but I never had hooker to compare them to
Old Feb 20, 2003 | 11:01 PM
vjo90RS8's Avatar
Car: 2002 Z28
Edelbrocks fit my car with no problems
Old Feb 20, 2003 | 11:39 PM
deadtrend1's Avatar
im running edelbrocks i bought used and sent for coating. I cut the Air tubes off completly and welded them shut. You can see the little nubs in the pics i attached of them. But luckly NJ doesnt have open hood inspections like CA.
Usually the passenger side is harder than the drivers side, but i already have the A/C and heater crap away so that side is no problem. The drivers side was a pain due to the steering .... but manageable.
I heard good things about hookers and headmans (both come with a y-pipe) Im not sure what other brands have a y-pipe, but a decent shop should be able to make you one fairly easily. SLP's are nice, but I think they are expensive and the power of a stock TBI car doesnt really need those.
Old Feb 21, 2003 | 12:29 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
My hooker 2055's fit real good but I guess they would be ruled out because I opened up the ball joint where the y-pipe hits the collector a little bit.
Old Feb 21, 2003 | 03:17 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Deadtrend1, Man you need to take some whitewall cleaner to that engine bay
Old Feb 21, 2003 | 04:59 AM
ctandc's Avatar
I have the Hedman's on my IROC. Mine were the smog legal headers, but somehow the AIR tubes magically disappeared
The fit very well. But if you're planning on keeping AC, you're going to have to do some SIMPLE fabricating to get the bracket to work with the headers...not hard at all.
Do a search in the EXHAUST forum for "Hedman headers install"
And you should find my pretty detailed post.
HTH
Old Feb 24, 2003 | 10:33 PM
Charlo's Avatar
gibson makes some quality headers for CA cars, the may be mostly trucks though.
Old Feb 24, 2003 | 10:39 PM
NJ SPEEDER's Avatar
all the major brands of headers seem to fit pretty good and have about eh same level of performance benefit. what makes the difference is a good y-pipe. slp and edelbrock are teh best at that. teh hedman/flowtech/hooker y-pipes neck down a lot and take away a good amount of teh flow you are trying to get. they are still a large improvement over stock, but for a few more bucks you can get the job doen with out any compromise.
later
tim
Old Feb 25, 2003 | 04:15 AM
RS91's Avatar
Edelbrock fit mine with no problem and I'm not even a mechanic....
Old Feb 25, 2003 | 10:41 AM
jlbolin's Avatar
ive got the flowtech's on my 91 firebird, driverside was easy, but passengerside had to have the motor mount broken loose just a bit and raise the motor just a few inches, after that it slid right in place.i got my headers at jegs, they were 106.00 after tax and shipping.
Old Feb 26, 2003 | 09:18 AM
91' Camaro Man's Avatar
I have full length headmans. The only problems that I had was I had to jack the motor up off of the motor mounts about 4 inches to slide them in. You will probably have to take off your starter too. Here is a word of advice...get the bottom of the car pretty high off the ground (ramps with 2x4's under the legs, tall STABLE jackstands,ect.) and slide the headers in from the bottom!!! This will make your life much easier installing the headmans at least. Also mine are not smog legal so I didn't have to worry about air tubes or anything, but they shouldn't be that big of a problem. With full lengths the collector ends up pretty close to the subframe on the drivers side. I think that they are probably pretty rare among 3rd gens because of the difficulty of instal and avalibility of aftermarket systems. I guess if I could go back I would do shorties with dynomax pipes. But my way was really cheap and it sounds gooood. Good luck! RACE ON!
Old Mar 8, 2003 | 12:00 AM
KiLLJ0Y
Guest
Posts: n/a
anyone have a picture of Hedmans Y pipe? ive never seen it.. if its like the stock one.. screw that...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
Wvcamaro
Sep 4, 2015 08:38 PM
hectre13
Aug 26, 2015 08:17 AM
