Question on AIR [smog] pump removal
Old Aug 21, 2001 | 08:02 PM
wpgmedic's Avatar
Just clarification more, I think...
Sorry...I went thru the archives and still had a few questions.
If I remove the pump off the block [this is for an LO5]is there anything that has to be blocked off there, or is it just a matter of bolt holes?
And, after I remove the AIR tubes, I cap the holes in the exhaust manifold with 1/4" brass inserts? I saw a post in the archives...these are threaded fittings?
To the best of my knowledge, this shouldn't produce any codes, right?
Anything else I should be aware of?
BTW, no inspections or sniffer tests here...
Thanks in advance...
Old Oct 5, 2001 | 02:09 PM
un4givin89's Avatar
These are the same questions I'm looking for answers to. Why no one replied is alittle distrubing. Lets see if we can't get some answers today.
Old Oct 5, 2001 | 02:47 PM
92Camaro305TBI's Avatar
Yes you will not get error codes... I removed the pump and still have the pully on.. Im waiting for the new belt...
It's just the same as plugging up the AIR tubes... I just kept the big AIR part where it separates and blocked it until lI get the headers without AIR on.
This question has been seen a lot lately and I think That is why noone is repling...
Check the TBI board and you will see a the topic "Can you name these, pics inside" It shows the pump...
the smog pump/AIR removes the hydrocarbons by pumping rick oxygen AIR into the exhaust manifolds...
NO HP gains and you may loose emssions just a bit.. no real differnce...cleans up a bit... too
check my ride in sig to see a pic of the pump...
DID this help you at all????
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
Old Oct 6, 2001 | 01:30 PM
RSS's Avatar
RSS
I took mine off. It's really easy if you have the right tools. Make shure you have all of the right tools first. You'll need a new fan belt. They cost about $30 (rip off). This is an easy mod and I do recommend it. You'll gain about 3HP and take off about 10lbs.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
3rdgenparts
Aug 8, 2015 07:09 PM
