Y-Pipe Differences
Old Oct 14, 2001 | 10:04 PM
leirch's Avatar
Y-Pipe Differences
Guys,
I have the TES headers from Edelbrock right now, Going to 1 3/4 SLP's sometime soon. I'd like to know if anybody can confirm if the y-pipe from Edelbrock is the same as the SLP y-pipe?
If I don't have to cut the Edelbrock y-pipe off and put the SLP one on I'd be REALLY happy...
Thanks,
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 14, 2001 | 10:24 PM
Tas's Avatar
Tas
AHAHAHAHAAAAAAAAAAAAA
SLP Y pipe is 1000000000000x better
ok maybe not that much but its MUCH better
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 14, 2001 | 10:27 PM
leirch's Avatar
Haha, Ok, Just wanted to see if there was a difference at all. I may just have to wait until I get the y-pipe and then compare the two. The engine is out of the car right now.. so I can do an easy comparison( go to www.geocities.com/leirch_/teardown if you'd like to check it out)
Brendan
Old Oct 14, 2001 | 11:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
http://24.1.139.249/images/082901/DCP_0273.JPG
From that pic the angles where the headers connect apper to be slightly different.
Aside from materials used, better is only a matter of opinion.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 15, 2001 | 07:10 AM
leirch's Avatar
Thanks deadbird, that answers the question to a T. Guess I'll have to swap the y-pipes..
Thanks again,
Brendan
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
Camaro_383
Sep 11, 2015 11:28 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
