gutting cat
Old Mar 13, 2003 | 11:59 AM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
gutting cat
what are the advantages of gutting it, how do u gut and? is it louder once its done? will it sound good? i have a 2.8 v6
thanks in advance
Old Mar 13, 2003 | 12:45 PM
LT1guy's Avatar
Car: 1987 Trans Am
To me its only worth doing as a temporary thing, say if your convertor clogs up and you have to be at work the next day. Its pretty simple, just unbolt the exhaust system from behind the convertor and start breaking out the honeycomb material with chisels, screwdrivers, hammers...whatever works for you. When you're finished, start the car and let it run for a minute to blow out any loose pieces, then reconnect the exhaust. If this is going to be a permanent mod, I'd recommend replacing the cat with a straight pipe, or welding a pipe through the convertor body so that it at least "looks" legal. A hollowed out convertor usually sounds pretty bad, esp on decel. A 2.8 V6 is likely going to sound horrible with a gutted cat, and its doubtful if it will give you much improvement...just more noise.
Old Mar 13, 2003 | 05:31 PM
Transmission: autos
i figured it would sound bad..i was thinkin running a pipe through it and bolting it all back together with u bolts? will that work?
Old Mar 17, 2003 | 09:54 AM
LT1guy's Avatar
Car: 1987 Trans Am
It'll work...at least eliminating the rustling sound you normally get in a gutted cat. I have no idea how it will sound on your car, though...I've only done it on V8s and one turbo V6.
Old Mar 17, 2003 | 10:53 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
From what I've read gutting a cat, will mess with the flow of the exhaust thru that section, so it's better off having a pipe in it's place.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
