O2 sensor question
Old Mar 17, 2003 | 02:38 AM
mess21's Avatar
O2 sensor question
heres the deal i have one single wire O2 sensor(not sure if all third-gens have only one single wire) and i have a auto meter air-fuel ratio gague that taps into the O2 sensor now since the O2 sensor runs on only mili volts and the gague takes power from it won't it send the ecm a false single my mechaniac agrees wit this thinkin??? anyone else
Old Mar 17, 2003 | 08:49 AM
377Z's Avatar
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
Your a/f ratio gauge should have seperate power wires for the gauge. Mine is the one with the tricolor LED display (I think from autometer, I'm at work now so I can't check) and has three wires-power, ground, and signal. Essentially the gauge is a voltmeter, and a voltmeter always has a high impedance (resistance) so that it draws a negligible current, and so does not disturb the circuit.
Old Mar 18, 2003 | 09:15 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
it should work fine as long as you have a stock setup (mine did, and i added a three wire heated 02 sensor).
the power wires will take care of the "power"...the signal wire really has nothing to do with it. you'll be all set.
-Brian
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
