Clogged Cat ??
Old Oct 20, 2001 | 08:48 AM
zax7d2's Avatar
Clogged Cat ??
1986 IROC-Z, 305 , 700R4 , 3.23 Rear
Recently the exhaust has taken on a noticably quite tone, kind of a "whoosh" sound. At the same time the power of the car has dwindled greatly. Going uphill the car will shudder and shake around 3000-3500 rpm and won't shift to third until you let off on the gas a little, but normal driving on flat land the transmission shifts fine. Don't want to replace the transmission if the problems lies in the exhaust !!!! Question - would a clogged converter cause problems that you could mis-diagnose as transmission failure ??? These shifting problems only occur under heavy acceleration, is the transmission missing it's shift points because the rpm's aren't getting there fast enough ?
Old Oct 20, 2001 | 12:52 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
How does your exhaust smell?
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
Old Oct 20, 2001 | 01:19 PM
rezinn's Avatar
Go hit your cat with a mallet and see if you hear anything banging around inside.
Old Oct 20, 2001 | 11:45 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
All you need to do is rap on it with a knuckle... unless it's hot, then I'd use a mallet ouch! If there is a rattle then the cat is busted and you need a new one. If it was gutted it would sound hallow. I assume you haven't gutted it though...
Old Oct 22, 2001 | 02:41 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
My exhaust smells like gas....actually my whole garage smells like gas after about 2 minutes of it being in there.
87 FireBird Formula
305 4bbl LG4
K&N Filter
Flowmaster 80 Series
Holley Quadra-Jet 650 CFM 4bbl Electronic Carburetor
P215/65R15 Tires
-----Need Upgrades-----
--Give suggestions plz--
http://members.tripod.co.uk/michigan34/car.html
Old Oct 22, 2001 | 04:39 PM
barryhasafirebird's Avatar
just fix it the old fashioned way - rip it off and weld a piece of exhaust pipe in its place! your car will sound meaner and you'll get better gas mileage, too!
1984 Firebird S/E
305 V8 (LG4), 5speed
Holley 650 cfm 4bbl
Edelbrock headers
Flowmaster 80 series
No cat
3.73 rear
P275 60 rear tires
P245?50? front tires
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
