Edelbrock Mufflers ...
Old Oct 24, 2001 | 11:32 PM
wickedcamaro's Avatar
i was thinking of getting the headers along with the cat-back exhaust system, im wondering if any one has a edelbrock muffler on their car .. i think its the rpm series , and also how it sounds ?
thanks
Old Oct 25, 2001 | 12:44 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Ive got the RPM series cat-back with stock cat and exhaust manifold...at idle, it is kinda quiet...little louder than stocl tho. When your revs get up to 2200-2600, it sounds sweet. Even better at WOT. It will probably sound much better with headers and a high flow cat though.
--Matt K
1982 Camaro Z28 5.0L 305
65000 Orig. Miles
Edelbrock RPM Series Cat-Back Exhaust
New Rochester Quadra-Jet Carb
New Water Pump & Belts
Hi Performance 8mm wires
Bosch Platinum Plugs
Hella Fog Lights
Coming soon (hopefully):
SLP Headers
Hi-Flow Cat
16" Chrome IROC Wheels
Edelbrock Performer RPM Intake
Crane Cams Hi-Output Ignition Coil
Old Oct 25, 2001 | 05:19 PM
poncho9789's Avatar
A guy I know has one is replacing the edelbrock rpm with a flomaster. His car backfired through the exhaust and caused the muffler to swell and break all the materials inside loose and clogged the muffler. Also I have talked to some of the mustang guys that have reported the same results from the mufflers with normal use. After seeing his experiance and hearing of many others with the muffler I would never owne one of these.
Thats just my opinion
Old Oct 25, 2001 | 08:40 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have the TES headers and catback system with rpm muffler. It's ok except I keep blowing out collector gaskets about every 1 1/2 months. Gonna get expensive since edelbrock replacements cost 15 bucks from JEGS. I now wish I had just paid more and went with SLP stuff.
Old Oct 25, 2001 | 08:44 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
<font face="Verdana, Arial" size="2">Originally posted by poncho9789:
</font>
When you say 'swell' does it kinda look like it exploded on the inside and puffed out?
Old Oct 25, 2001 | 10:23 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i bought the edelbrock rpm series catback and it sounds sweet, i dont like the sound of flowmasters, and i had problems with my distributor cap, i was backfiring through the exhaust constantly, my muffler is still fine, if i had a choice to do it again, i'd probably by the same thing.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 26, 2001 | 06:14 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I wish mine were louder, but it sounds very racy on the outside. I deleted the cat and it made a difference in sound, now I just need some headers. BTW I've rigged my exhaust so that I can have only the 3 inch over the axle pipe, holy crap, now that is loud. louder than just the y-pipe even. (megaphone pyshics) (manifolds)> (2 1/4)>(2 1/2)> (3)
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
