Could I Do This?
Old Oct 31, 2001 | 12:27 PM
AZ88Maro's Avatar
Could I Do This?
Hope the picture worked, my first time posting one. If not go to:
http://falsehope.tripod.com/wantedexuast.jpg
Well i want pipes to come out just before the rear passenger side tire. What do i need to do this. And can i keep it street legal doing this. Thanks A Lot. Bobby.
[This message has been edited by AZ88Maro (edited October 31, 2001).]
Old Oct 31, 2001 | 01:35 PM
cort351w's Avatar
That looks similar to what CARNDRVR has set up. Do a search for his name I think in the exhaust board but try others. Anyways, there is a really big post with pictures of his car and a lot of other people replied with how they put duals on. Why do you want to put both pipes out the pass side? Good luck getting mufflers (and cats?) under the car. I wanted to put cats and mufflers under the car, but I don't have the clearance. If you're not using cats, it would be easy.
I am putting 2 pipes over the rear axle where the 1 stock pipe goes. I am using car-sound 2 1/2" cats either in the stock location (dual cats stock) or one on each side. At the end will be 2 Borla 2 1/2" XR-1 Sportsmans, side-by-side and perpendicular to axle, I hope. I want them centered.
Anyway, after planning this setup for a month and a half now, I don't see a practical way to put true duals on my car. I want to keep my backseat, which means keeping the rear floorpans, so I can't put mufflers under the car. Those XR-1s are 4 1/2" thick so I would have about 2, maybe 2 1/2" clearance, depending on how I hang them.
But just mufflers, or just ******* pipes should be easy.
