TES or SLP
Old Oct 31, 2001 | 11:41 PM
Dauntless's Avatar
TES or SLP
which would be best for my engine? i've noticed that the TES is significantly cheaper, but SLP claims more gains over the TES. would these fit W/P SportsmanII or Torquer heads?
1984 Z-28, 305HO 4bbl, t-tops, K&N, Flowmaster 80 Series with 3" tips. Planning a massive modfest. It's gonna be one gangsta of a street demon.
Old Nov 1, 2001 | 01:38 AM
Jza's Avatar
Jza
wrong post
[This message has been edited by Jza (edited November 01, 2001).]
Old Nov 1, 2001 | 08:01 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
If you plan to heavily mod the engine or even swap it for a 350 or larger(why wouldn't you?)go with the SLP.They are bigger and will outlast the TES,so the money spent will be worth it.Do a search on this,there has been much debate over these two headers.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Nov 1, 2001 | 04:45 PM
breathment's Avatar
SLP is alot better then TES, you get what u pay for. Now on a STOCK 350, they might make around the same (SLP more), but the more mods u do, then the more reasons to get SLP. SLP did a dyno test on their headers and TES headers, needless to say SLP did alot better, however they did it on a 383. Either way, go with SLP
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 1, 2001 | 09:11 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
for a 305, I would go with the tes. you will go faster. unless you plan big big future mods....
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
