What coating is the best >> and more?????
Old Nov 1, 2001 | 09:43 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Getting a new set of SLP's soon
I have a few questions ..
First Is there any point to putting them on a 305 nearly stock {but Nos shot}??... (cause I'm bulding a 383 right now) and I want to use them on this motor if I will see any good gains..
Second What Type of coating is the best ?? "I have never coated headers before so I know nothing about it" I dont want to go too much$$
Third how long will the coating last and keep it's look???
and last How well will the SLP air injection hook up ??? any mods/adaptors??
I know that's a lot of question but if you can help I would be greatful..
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Nov 1, 2001 | 11:02 PM
Tas's Avatar
Tas
SLPs don't rust so you don't "need" coating. Jet Hot is a big name for coatings. People that have put them on 305s have said nothing but nice things.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 1, 2001 | 11:06 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
How much would I expect to pay to get them coated ?
Hecubus
Old Nov 1, 2001 | 11:09 PM
Tas's Avatar
Tas
$250 I think
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Nov 1, 2001 | 11:17 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Is it really worth it ??
I thought that there is a hp gain to be made when you get them coated
Hecubus
Old Nov 1, 2001 | 11:19 PM
Tas's Avatar
Tas
There should be a gain because the gas stays hotter but I really doubt its worth anything close to $250.
Old Nov 2, 2001 | 01:28 AM
Jza's Avatar
Jza
On SLPs, it's worth it if you want it to look good and stay looking good forever. SLPs should last forever without the coating, but they'll discolor slightly. So basically, it's mostly about your concern for their appearance. On the performance aspects, well, all most of us have is the propaganda on it.
Jet-Hot is supposed to last and keep it's look for the life of the headers or they recoat it for free, unless you modify or weld on them (so states their warranty), or the exhaust temps go past 1300 degrees F. They have a slightly more expensive coating that's good up to 2000 degrees IIRC, but it's not available in as many colors as the 1300.
The SLP installation kit comes with everything you need to install the headers, including the AIR hose "adapters".
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
redformula88
Oct 14, 2015 06:08 PM
