SLP's on 91 305..please help no smog...
Old Nov 1, 2001 | 08:01 PM
91camaro305RS's Avatar
ok o deleted the smog...and are set on the slp 1 5/8 headers i think....they come with y pipe right.....and i have no cat so i will have to get it welded i'm sure....but does the slps without air tubes still have the oxygen system hole?
please help
thanks
nathan
Old Nov 1, 2001 | 11:22 PM
Tas's Avatar
Tas
If you're not getting smog legal headers then save yourself a lot of money and get the hookers. You can even get them coated from the factory.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 1, 2001 | 11:25 PM
whats the part number for the ones without the air tubes.... coated also
thanks
Old Nov 1, 2001 | 11:26 PM
Tas's Avatar
Tas
https://www.thirdgen.org/messgboard/...ML/002750.html
Old Nov 2, 2001 | 04:37 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you have the money, and don't have emissions testing, go with the 1 3/4" long tube Hooker Super Comps and the Mufflex Y-pipe. It is hands down the best header setup for an F-body..... You will never have to upgrade the headers again if you go that way...... They are part number 2210 and 2210-1 for coated - $380 uncoated, $570 coated at Summit.... Mufflex sells the Y-pipe for $279 but I think you will have to pay to have the O2 sensor bung welded on.... Or you can have an exhaust shop make you a Y-pipe.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 2, 2001 | 05:53 AM
Tas's Avatar
Tas
1-3/4 long tubes are too big for his 305 though
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
