pipe through CAT
Old Mar 25, 2003 | 08:15 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
pipe through CAT
ok i wanna run a exhaust pipe through the CAT so it looks as if i still have one that works but it doesn, will that work?, is there room in there to run a 2 1/4" pipe through?
thanks in advance
Old Mar 25, 2003 | 08:18 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Only if you do not have Emisson Inspections.
Old Mar 25, 2003 | 08:20 PM
Transmission: autos
i do, once a year im just gonna take the pipe out for nspection, but there is room in the cat to run it?
Old Mar 25, 2003 | 09:43 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
If you aren't worried about getting caught by a cop or something just do what I did: Go to a Carquest store and get some exhaust pipe tubing (whaterver fits your car) and 2 clamps and put the strait pipe in PLACE of your cat until you run emissions - put the cat back in then.
It is not possible to run a pipe through the cat w/o wrecking the cat - I found this out when I ripped all the **** out of mine to try to free up the flow.
Hope this helps.
Old Mar 26, 2003 | 06:50 AM
DJP87Z28's Avatar
Lot of work and effort for little or no gain, just buy a hi-flow Cat and be done with it.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
