What Am I Going To Do? Help
Old Mar 27, 2003 | 10:15 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I thought I had decided to stick with my cat-back and have the long tubes connect to it with a y pipe. One problem though, no shops around do mandrel bending. They say if I get mandrel bent pipe then they work with that, but if bends have to be made to that, wouldn't that defeat the purpose of mandrel bent?
Anyone have any ideas, I'd like long tubes into my Hooker cat-back, just in case I have to go thru emissions soon, at least they can hook their hoses up to tailpipes.
Old Mar 27, 2003 | 10:46 AM
darbleinad's Avatar
Car: 84 Trans Am
why cant they hook their hoses up to true dual exhaust? its still 2 pipes.
what you could do is put a length of pipe in each exhaust tube with flanges on each end, so you could unbolt these small sections of pipes and bolt in 2 cats with flanges (one on each pipe) when you need to be etested. just go to the wreckers and grab another cat, as i seem to recall in many of your other posts you mentioned you are still running a cat with your catback system. then go the muffler shop and get them to put flanges on all the pieces.
Old Mar 27, 2003 | 12:52 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can get pieces at www.JCWhitney.com pretty cheap. They sell them 45*, 90*, and 180* IIRC.
http://www.jcwhitney.com/product.jht...180618&BQ=jcw2
I'm sure Summit or Jegs sells them to but I know JC Whitney carries them in stainless.
If you need to get stainless pipe, go to www.onlinemetals.com They don't have the bends, but the price of the pipe is A LOT cheaper than any other place I've found.
Here's a link for the T-304 stainless to match the bends that JC Whitney sells.
http://www.onlinemetals.com/merchant.cfm?id=19&step=2
JC Whitney has those same bends in aluminized steel if you're on a budget.
Old Mar 27, 2003 | 01:31 PM
Car: 99 Formula
Axle/Gears: 342
If I do duals, I was going to have the pipes dump before the axle. I still may do that, we'll see once I get the car started and put it on some jackstands, to see what kind of room I have to play with.
Old Mar 27, 2003 | 01:35 PM
darbleinad's Avatar
Car: 84 Trans Am
there will be room....you only have 2 choices here...duals or a custom y-pipe and it sounds like you cant find a good place to do a custom y. i am throwing on hedman long tubes as soon as school is done and they will be hooking into my dual exhaust that i already have. run dynomax bullet mufflers for more clearance.
Old Mar 27, 2003 | 11:04 PM
25THRSS's Avatar
A lot of companies sell pre mandrel bend pipe in all kinds of degree bends. Just look in summit or jegs or something like that. Good luck
Old Mar 28, 2003 | 01:20 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Doesn't Magnaflow make a y-pipe for hooker long tubes? I'm sure they do... but I can't remember if it's only for their 4" exhaust or not.
