SLP Headers
Old Nov 27, 2001 | 04:39 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
SLP Headers
Do these headers just bolt up or do they need welding? Please advise.
Thx!
  • 92 CAMARO RS 305 TBI (PURPLE HAZE METALLIC)
  • 700R4 TRANNY
  • EDELBROCK 14 X 3 OPEN ELEMENT AIR CLEANER
  • EDELBROCK ELITE SERIES VALVE COVERS
  • ALPINE 7858 CD PLAYER
  • DHD 4 CH 400 W AMP
  • MTX 5 1/4 COMPONENT (FRONT)
  • MTX 6 X 9 (REAR)
  • FUTURE MODS:
  • SLP 1 5/8 HEADERS
  • CATCO 3" INLET/OUTLET CATALYTIC CONVERTER
  • FLOWMASTER AMERICAN THUNDER CAT-BACK SYSTEM 3" INLET DUAL 2 1/2" OUTLET W/ 80 SERIES MUFFLER
  • HYPERTECH 180* THERMOSTAT
  • HYPERTECH 180* FAN SWITCH
  • TRANSGO SHIFT KIT
Old Nov 27, 2001 | 04:51 PM
breathment's Avatar
im pretty sure they bolt up to everything just fine.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 27, 2001 | 07:36 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
They will bolt up fine. The only problem I had was from the Y pipe to the cat. I ended up having to weld it to the cat since the old Y pipe was a POS.
Old Nov 28, 2001 | 01:28 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Welding will be required, no matter wich brand headers you pick. You gotta connect them to the Y-pipe or to the individual cats(Dual cat 3rdGends).
You can get away with clamps but I don't recomend them because it will sound like you have an exhaust leak, which it will actually be.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners w/Edlebrock Base, March Power/Amp Pulleys, Richmond 4.10 gears,265/50/16 BFGoodrich rear tires.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
