Valve Cover Breathers
Old Dec 5, 2001 | 01:25 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I am not sure if this belongs on this board but...
I have two Mr Gasket Chrome valve cover breathers and I was wondering what is needed to install these...apart from the obvious "pull out the PVC filter and push in the chrome ones" ... the PVC filters have vacuum on them so will I just have to disconnect there vaccuum lines and block it off or am I way off base here?
I am at a disadvantage as my car is stored and I can't tinker with it....just looking for ideas.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Check out my ride in the Readers Rides
https://www.thirdgen.org/rides/index...ew&rideid=6920
Better to look at it than to look for it "
Old Dec 5, 2001 | 11:20 PM
BitchinCamaro's Avatar
You will need to cap the vacume lines. Plus you will be cleaning your engine more often, with the PCV all the crankcase vapor get sucked into the intake air, with breathers it will coat your engine in a thin film of oil.
Old Dec 5, 2001 | 11:28 PM
Tas's Avatar
Tas
just leave it alone
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 6, 2001 | 06:52 AM
87ROCZ's Avatar
Is there any real benefit to using valve cover breathers? Everytime I see a "performance engine" in a car 99% of the time you see valve cover breathers.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Old Dec 6, 2001 | 10:31 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was told there is, but think about it how much could it really help. I have one breather and the PCV hooked up on the other side.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 6, 2001 | 12:19 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
You've got TPI... there's no reason to remove those. Now if you were TBI switching to open element THEN you could start thinking about it.
Old Dec 6, 2001 | 05:06 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The benefit to running a crankcase breather that has an open element is that it allows the cankcase to vent pressure out into the atmosphere freely which saves on gaskets, rings, and allows the engine to rev slightly smoother, since the crankcase will basically not build any pressure at all. There is no reason not to do this mod on a TPI engine versus any other type of engine. Now, the install of a breather and the subsequent capping of the vacuum lines that used to go onto the breather line on the side of the TB of a MAF system will cause a few small problems with the system as it is programmed to have that small amount of air come into the air stream behind the MAF and it is calculated into the PROM. So when you cap the line and install an open breather, you will be causing a small fluctuation in the air coming into the engine. But I can also say that I have an open breather on the passenger side VC of my engine and have installed it on many other cars without having any problems. Basically I have found that whatever effect that this 'mod' has on the air coming into the engine is not enough to cause any major problems. But then again, I burn my own PROMs......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
