Will the SLP headers bolt up to fast burn heads?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah they defnitley bolt up to vortecs..and they will bolt up to the fast burns as well.
the only thing is that on the fast burns, they are already "ported" from GM so the ports may not match up perfectly (the exhaust ports may be larger than the headers). the 1-3/4" SLPs should fit better than the 1-5/8" ones.
-brian
1991 Camaro RS
GMPP 350 HO crate engine w/TBI
Homepage z28boy@twcny.rr.com AIM - "Z28 Boy"
[This message has been edited by Z28 Boy (edited December 11, 2001).]
-brian
1991 Camaro RS
The exhaust ports on FastBurn heads are MUCH different from the ports on Vortec heads!!!
Get a GMPP catalog to see the difference. They will physically bolt-up, but the ports are in a different location and are of a different shape, compared to Vortecs!!!
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
The ports on fastburns are D-shaped. I believe Hedman has a new header that will bolt to them correctly. Try www.paceparts.com.
The 1.75in SLPs will work. I have them on my fast burn heads. Yeah, the exhaust port is a D-shape and it is raised a bit higher too. With the large diameter of the primaries on the SLPs, and the thick flange, I was able to do enough grinding to get a good match. You will also have to trim the header gasket. I have no leaks and Im using a POS gasket too. There are plenty of other guys that have this same setup as well. Doubt it would work with a 1 5/8 header though.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
