the cat
Old Dec 12, 2001 | 07:29 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
the cat
Is it illegally to take off a cat? I want to get a free flow cat from like catco but I heard that it is illegal to take the cat off a car. My car passed the smog check perfectly here in CA. Does that cat have to be damaged or something to be replaced?
Old Dec 12, 2001 | 08:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I didn't think you could do much of anything on a car in CA without it be illegal. It is illegal in MD for a shop to take your cat off, but I'm not sure about whether the owner could. Just replace the cat with a hi-flo one and you won't notice a difference than with straight pipe.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 12, 2001 | 08:57 PM
BAK12484's Avatar
im pretty sure anywhere you go, it is technically illegal to remove the cat, unless your stock one broke and you needed to replace it. I heard that if convicted, it could be a $10,000 fine and considered a federal offense - but then again how many people have u heard of getting busted w/ no cat
Old Dec 13, 2001 | 08:54 PM
trans87's Avatar
So if the cat is bad are shops legally able to put a new cat in? Like for some unforseen act where holes might be put in the cat would they be able to replace it with a high flow cat?
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
