where can i get just the 3" i pipe
Old Apr 27, 2003 | 12:50 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
where can i get just the intermedite pipe. i want it in 3". must be mandral bent. i realy care wheather its made out of. but i do need it so it will fit a cat. the car is a 89iroc lb9/700r4/ single cat. i plan on using a spintech mufler and having my boss' friend fab me up some sick tail pipes. (full 3" into a slash cut that comes off level with the ground. then i'll pholish them.)
also i will be ptting on a set of headman hedders and y-pipe
Old Apr 27, 2003 | 02:27 PM
88WS6TA's Avatar
Walker Dynomax. The 3" i-pipe is 2 parts: 44063 Front I pipe & 43248 OA I pipe.
HTH
Old Apr 28, 2003 | 11:01 AM
Engine: peanut LB9
thanks, i'm just not sure if tey are m-bent. so i'll call summit and find out. thanks again-
Old Apr 28, 2003 | 11:12 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
They are mandrel bent. All Dynomax stuff is.
Old Apr 28, 2003 | 03:14 PM
Engine: peanut LB9
thanks, do they sell the matching 3" tips cause that would be much easier then tryin to make them
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
