questions
Old May 6, 2003 | 10:15 PM
agibby5's Avatar
Car: 1986 IROCZ
Transmission: 700R4 w/ stage 2 shift kit
questions
I just put on the 68470 hedmen headers and the y pipe to a straight pipe to the flowmaster 3 chamber muffler. These headers dont have AIR, so i ripped off the emissions crap on my car. what will i notice? good/bad differences....? what should i worry about?
Old May 6, 2003 | 10:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think it might cause an O2 sensor problem, leading to horrible gas milage, but I could be mistaken.
Old May 6, 2003 | 10:28 PM
agibby5's Avatar
Car: 1986 IROCZ
i have the o2 sensor welded into the ypipe
Old May 6, 2003 | 10:32 PM
KYL98's Avatar
Car: 1991 Z28
From what Ive gathered....the AIR system is mostly for idling and de-accelerating.... I cant see where that would pose a major problem for the 02 sensor...as long as the car is tuned correctly. I havent had any problem with mine....my smog stuff has been off for years and I havent noticed a decrease in mileage, but then again...my car is a 355, not a 305 with tbi or a carb...But, it should be ok.....dont hold me to it...
Old May 6, 2003 | 10:33 PM
agibby5's Avatar
Car: 1986 IROCZ
mine is a 305 with tpi
Old May 6, 2003 | 10:38 PM
KYL98's Avatar
Car: 1991 Z28
Only thing I could really tell ya is to try it......It should be ok....I know when you take off the smog pump, it will throw a code in the ecm......till you get a new chip. I did seem to notice a little better throttle response, and the engine seemed to run cooler...but that might have been in my head..
Old May 6, 2003 | 10:43 PM
agibby5's Avatar
Car: 1986 IROCZ
before i did the headers i unplugged the air pump and removed the belt for a few hundred miles and no SES, so that was my OK to get going on the headers...so far no AIR, and no SES
Old May 7, 2003 | 02:09 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Shouldn't throw any codes. Run mine for 2 yrs with no AIR or SES light.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
