Dual Cats
Old May 13, 2003 | 12:18 PM
PsychoGTA's Avatar
Dual Cats
I have dual cats on my car. I wanna keep it dual, but I all already gotten a 3 inch system before and after the cat. So, my question is which cat thats 3inches can I fit in there?
Thanx,
PsychoGTA:lala:
Old May 13, 2003 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You've got me confused. Do you mean you have a 3" cat-back that hooked up to the dual cats, and now have a y-pipe that has a 3" connection at the cat? And you're wondering how to connect the two with a 3" cat?
If so, the only way would be to modify the cat-back connection to the cat. For that, you could use a universal 3" cat and have a pipe inserted after the cat to connect to the cat-back where it is one pipe (cut off the y), or get a direct-fit cat for '86-'90 TPI applications, and have the cat-back modified to connect to it.
Another possibility to consider is cut off the 3" portion of the y-pipe and extend the individual tubes to the individual cats. That would be my choice if I already had dual cats, but it's not my car.
Old May 13, 2003 | 04:02 PM
PsychoGTA's Avatar
I got brand new headers. From the headers to the dual cat, im gonna be running 3 inch pipes. Because I already got the 3inch cut-out. I dont have no y-pipe, thats y i'm want to get 2 3inch cats. Then after the cat i'm gonna have a 3inch y-collector.The exhaust I got is a 3 inch inlet and 2.5 inch outlet. So do u think I can fit 2 3inch cats under there? Hope this makes better sense.
Thanx,
PsychoGTA:lala:
Old May 13, 2003 | 06:58 PM
five7kid's Avatar
Probably. The inlet/outlet size doesn't usually relate to the body size.
What kind of headers? 2-1/2" from each side to 2-1/2" dual cats y'd to 3" cat-back would support most any SBC.
Old May 13, 2003 | 08:13 PM
KYL98's Avatar
Car: 1991 Z28
heres a pic of the dual cat setup if youd like to see it.....
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
