How to keep collectors bolts tight ?
Old May 14, 2003 | 02:50 AM
Odyssey's Avatar
I've had an ongoing problem with collector gaskets that keep burning out. Tonite I just changed one AGAIN. I noticed the bolts were pretty loose when I took them off. I used those "slit circle" type of locking washers to keep the bolts from loosening. What else can I do ? Should I use different types of washers until one works ? Use two nuts on each screw ? Any ideas ?
Old May 14, 2003 | 01:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Double nut them with dead soft aluminum gaskets, unless they are warped badly, that should cure it.
Old May 14, 2003 | 01:49 PM
DreamState21x's Avatar
exhaust
Like any components that heats up the metal expands when it heat and shrinks when it cools.. Tighten them down when they are cold, then crank the car and let it get to normal temp then let the car cool down(completly, to where the metal is cold again) and tighten them some more, do this 3 times.. It is time consuming but the best way to get them tightend all the way down...
Then if you blow one and the bolts are still tight you probrably have a slight warp on the flange... Good luck...
Old May 14, 2003 | 03:06 PM
383 rocket bird's Avatar
AM I a fool for suggesting a thread locking compound.
Old May 14, 2003 | 05:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try some Stage 8 collector bolts.
Old May 14, 2003 | 05:58 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
it would burn up
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
