Question on not having a cat
Subscribe
May 14, 2003 | 05:09 PM
I dont have a catalytic conv. on my car and is has white smoke during startup and low speed driving. i do not think it is runnin lean but it may be burning antifreeze. Could not having the catylitic conv. produce white smoke?
Reply 0
May 14, 2003 | 05:19 PM
No. The gasses that the catalytic converter is designed to absorb (for want of a better term) are not visible ones, so the white smoke you see is a byproduct of something burning that shouldn't be. The chances are that as it's white smoke, it's water/antifreeze.
Reply 0
May 17, 2003 | 05:08 PM
Could be a light blue(oil). Give it a quick smell. If you are running antifreeze, it will smell kinda sweet if it's 'burning' antifreeze.
Reply 0
May 18, 2003 | 08:06 AM
Smoke on start up on SBC = VALVE SEALS.....
Reply 0
May 18, 2003 | 09:24 PM
Quote:
corection: BLUE SMOKE on start-up= Valve seals
white smoke is coolant
and black smoke means your running too rich
Reply 0
May 19, 2003 | 01:10 PM
If happens in cold or damp weather & goes away after the engine warms up, it's normal condesation burning off & yes it does happen without a converter. White smoke before & after warmup would be antifreeze & as said above, has a "sweet" smell.
Reply 0
May 19, 2003 | 01:45 PM
Just because it's white doesn't mean it's water/antifreeze. It's a good chance, but it's not etched in stone that it's water/antifreeze.
I have an '83 C10 with a 305, and EVERY time I start it, it blows white smoke. And yes it's white. White as the pure driven snow.
I know it's oil. It smells like oil. Plus I have to add about 1 quart every 4-5 times I drive it (I don't drive it often).
I've had the truck for 1 yr. and the coolant hasn't gone down at all, so I know it's not that.
Do the smell test. If you have to, put a rag in front of the tailpipe while someone else starts it up, then smell the rag. It's safer that way.
Reply 0
Subscribe
