y-pipe
Old May 19, 2003 | 06:43 PM
red rs's Avatar
y-pipe
I just picked up a set of used headers for my '92 rs 305tbi but do not know what brand they are all they have is mr. gasaket stamped in them they have 2 1/2 collectors the problem is where do I find a y pipe to bolt up to them and what size y pipe should I use
Old May 19, 2003 | 07:07 PM
darbleinad's Avatar
Car: 84 Trans Am
flowtechs have 2.5" collectors. so it could be a set of flowtechs, or it could very well not be either. post a picture if possible.
flowtech does sell their y-pipe seperated if they do indeed turn out to be flowtechs.
Old May 19, 2003 | 07:10 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Just to be sure are they shorties?
Old May 19, 2003 | 07:15 PM
red rs's Avatar
thanks for the quick replies yes they are shorties also they do not have provisions for a 02 sensor or air injection I was told they came off a '84 trans am they air injection is getting ditched and I will weld in a fitting for the O2
Old May 19, 2003 | 07:23 PM
darbleinad's Avatar
Car: 84 Trans Am
i was under the impression all the flowtechs came with an O2 bung welded to the collectors but not drilled through. thats how mine came, cause I didnt need the O2 sensor. you can probably buy an emissions legal set with the bung already drilled and tapped.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
