Header install question
Old May 25, 2003 | 11:48 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
First off, I drive a 1988 GTA with 5.7L
Just got finished installing some SLP headers (took about 9 hours) and when I took it out for the test drive, it was idling really rough like it had a huge cam in it and also it felt like it didn't have power brakes. Had to put the ****er to the floor to get it to stop. Checked for pinched lines and would cause. Thought it might be a vacuum leak but not for sure. Any suggestions would be great.
Old May 26, 2003 | 12:47 AM
Dan88IrocZ's Avatar
Did you reconnect your 02 sensor (dumb question)???
Did you cross any wires from the install??
Old May 26, 2003 | 02:26 PM
MCas7's Avatar
That defiantley sounds like a vacuum problem to me. If you breaks didn't work that good and it was running really rough? Sounds like you might have knocked a vacuum line off somewhere.
Old May 26, 2003 | 02:49 PM
MdFormula350's Avatar
the only thing i can think of is the main vaccum hose on the top of the booster.
did u install slp 1 3/4? if so u did you have any problems.
Old May 26, 2003 | 08:40 PM
Car: 1988 GTA
Transmission: TH350
Found the problem. I had left off the brake booster vacuum line to the plenum. Yeah they were 1 3/4 SLP's. No real problems installing them. Only problem was the far rear bolt on the pass. side of the header. Was just hard to get a wrench or socket on it.
Took us about 9 hours all together.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
