Exhaust on LS-1
Old Jul 24, 2003 | 07:51 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Exhaust on LS-1
This is kindof a cross-topic thing because it has to do with custom exhaust manifolds. for 3rdgen. It also pertains to the motor swap so i posted in both locations
I am currently doing an LS-1 swap and was wondering about headers as well. I am aware of the differences between the L98 and the LS1, but I am unsure of the dementions of the exhaust exits and bolt pattern. I am wondering..
L98 header flange
o oo o
1 23 4
LS1 Header flange
o o o o
1 2 3 4
L98 header on L98 flangeflange
o oo o
1 23 4
L98 headers adapted to LS1 flange
o o o o
1 23 4
note the center 2 tubes are modified
Pardon the crude interperatation.
wondering if the distance between holes 1 and 4 are the same on both the L98 and the LS1.. would it not work then to just change the header flange from an L98 flange to an LS1 flange (for bolt holes) and then modify the set of L98 headers to go into the LS1 flange?
if it were that simple it could be done from just about any exhaust shop if given the proper dimensions.
hopeuflly this can be done, I was hoping to adapt a set of hooker 2055's to an LS1 in this manner.
EDIT: spacing was all messed up on it. couldnt fix it but I think you get the picture.
Old Jul 25, 2003 | 07:51 AM
bigals87z28's Avatar
Car: Check The Sig
umm to save you time, you could do one of several things...
1: Use the existing manifolds... .they flow pretty good till your around 375hp. Maybe a set of Z06 manifolds would work?
2: Using manifolds, make a header flange and then adapt the tubes to that.
3: Find someone who has already done this! Im sure third gen resourse would give you plenty of info on what they did, though i think they did use the existing manifolds and custom bent exhaust from there.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
