Stuck nut/bolt solution
Old Jul 25, 2003 | 10:15 PM
lykan's Avatar
Hey guys, new to this board, it's my first post, not sure if this is the right forum but here goes.
About 7 years ago I stripped the H_ll out of a carb bolt (philips tiped screw)
We had absolutely no way to get this bolt out, and I had to have thje carbback on to go to work.
I Mc Guyvered a solution that has worked for m,anhy a stick bolt, and in fact sometimes wortks better than the standard bolt head.
I just picked up a file, and filed down the edges of the striped bolt nice and sqaure so it would fit a 1/4" wrench nice and tight, with a good grip from a craftsman wrench it came off nice and easy.
I have used this solution on many a bolt/nut since, and it has saved my knuckles more than once. Now I always keep a good file handy to get out those nasty bolts.
P.S. it also works on broken off bolts if enough is sticken out to be able to file it to a square point
Old Jul 29, 2003 | 10:59 AM
87camarodan's Avatar
my tip for tight areas
I had some trouble with some nuts that were holding my old exhaust manifolds on, after fighting it for a long time we went out and got a pretty long chisel and used a big hammer, after a while of beating on it I took the vice grips to it and peeled off a few layers of the nut and then it came loose and the vice grips took it the rest of the way off, and all that was done on the rear passenger side bolt for the exhaust manifold, on the nut that holds my chrome dipstick tube up.
we should have a sticky post about what people do to fight bad nuts and bolts out, not a bad idea
armybyrd
Sep 28, 2023 12:16 AM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
