L69 and High-Flow Cat
Old Aug 15, 2003 | 06:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Who makes a four-bolt, high-flow cat for the L69?
JamesC
Old Aug 15, 2003 | 10:49 AM
bigals87z28's Avatar
Car: Check The Sig
lots of people im sure... check catco, random tech, and magniflow.
Old Aug 15, 2003 | 02:54 PM
JamesC's Avatar
I've done some seaching, but I've only found one four-bolt (Catco), which is made for a Vette. I've seen nothing, and I mean nothing, for a direct-fit to an L69.
JamesC
Old Aug 16, 2003 | 06:18 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i make a high flow cat for any car, heres how, remove the stock cat, smash up and remove the insides and re-install
Old Aug 16, 2003 | 10:48 PM
25THRSS's Avatar
http://www.thunderracing.com/index.c...ategoryid=1034
second from the bottom
Old Aug 17, 2003 | 04:01 PM
JamesC's Avatar
Oops, I overlooked the part: CTO-4116.
JamesC
Old Aug 19, 2003 | 02:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The L69 cat, IIRC, is the same as that used on the Corvette.
Old Aug 19, 2003 | 02:38 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
I just got a Catco from Summit. Called them up and told them what car I had, they sent me the correct part (much to my surprise).
Yes the L69's came with a "Corvette" cat, but the L69 uses a different "F body" flange/bolt pattern then the Vette.
Hey James.
You only need to show your Signature once per thread. Not every post. Waste of bandwidth.
Old Aug 19, 2003 | 03:09 PM
JamesC's Avatar
I'm currently using the 'Vette converter. It is, however, a different part number (CTO-9143) from the number I've listed above. It looks a bit different as well, as can be seen at Summit. The four-bolt flanges must be the same or very, very similiar, since the 'Vette converter bolted up--as I recall--as if stock to the L69 system. The y-pipe outlet and the 'Vette converter inlet, in my opinion, don't mate well. Quite frankly, the 'Vette converter appears to neck down considerably.
JamesC
You're correct about the band width.
Old Aug 22, 2003 | 10:24 PM
83_1/2 L69's Avatar
Engine: 305 CC-carb
Catco #4116. Bolted right up in my 83 L69.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
