Questions about header gaskets and bolts
Old Sep 19, 2003 | 10:55 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Well, my hooker 2055's are on the way and now I'm wondering about gaskets and bolts.
Gaskets - I know anything is better then what they send you. So, do I go with the copper ones or the soft aluminum ones? Any brand recommendations?
Bolts - I've heard both good things and annoying things about the Stage 8 bolts. Will any good bolt do (ie ARP) or does it really matter? Or are Stage 8 bolts a necessity? If so, what size are yall using?
Semper Fi,
-The Gunny
Old Sep 19, 2003 | 12:32 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Any copper or aluminum gasket will work fine, I'm using Percy's Aluminum and haven't had a problem. You can even use a good Fel-Pro gasket if you want. The trick though is keeping the header bolts tight. It doens't really matter which bolts you go with as long as they stay tight. When they loosen is when gaskets will blow/leak. If you don't want to touch the bolts after you put them in, I reccomend the Stage 8 bolts. Otherwise if you don't mind tightening them every one in a while (every oil change would be good) then you can go with some ARP stainless ones or something of that sort.
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
