Stuff on Cutouts I found
Old Oct 16, 2003 | 06:13 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just noticed this. Mr Gasket makes a cutout that you control with a cable! Summit
I would get it if it came in 3 in. Anyone else know of anything like this?
If not I would like to get summits cutout. Not a bad deal for 26 bucks
Later in the future would be an electric cutout. We'll see if another deal comes around.
Old Oct 16, 2003 | 09:22 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
the pull cable one sucks in my opinion. the cable gets caught and won't push/pull sometimes. i always ran with mine open, so i just took the cable off and kept it open all the time.
Old Oct 19, 2003 | 12:09 AM
prophecy xi's Avatar
if u like those youll love the quick time electric cut outs you can adjust the with a switch. makes a goos sounding echoe if you open them half way. they come in 2 1/4 2 1/5 and 3 inch
Old Oct 19, 2003 | 12:50 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If I wanted to get an electric cutout, it would most likely be a Mccord. I don't know of any others that will bolt up to a cutout. Wait, now that I said that I thought of this. Buick
Old Oct 19, 2003 | 01:26 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I absolutely love my Electronic McCord Power Plate II Cutout....one of the best things I've bought....can have it NASCAR loud...or Flowmaster loud...the best of both worlds... ....I've definently busted alot of ricers ears out there
Old Oct 19, 2003 | 08:37 AM
thecoolone's Avatar
Car: 89 GTA
Got a link for the McCords? How does it exactly hook up/install?
Finally got around to ordering my headers and I guess now would be a good time to look into cut outs.
Old Oct 19, 2003 | 08:39 AM
Engine: 5.7
here ya go: http://www.mccordcg.com/mpp/pictures.htm
Old Oct 19, 2003 | 09:53 AM
thecoolone's Avatar
Car: 89 GTA
ty.
Old Oct 19, 2003 | 07:11 PM
25THRSS's Avatar
I would go with the qtec electric cutout.
Old Oct 19, 2003 | 08:24 PM
Engine: 5.7
y?
Old Oct 19, 2003 | 08:27 PM
25THRSS's Avatar
Originally posted by 84customZ28
y?
Well the qtec gears are all metal, unlike the mccord which cuts some corners with a few plastic ones. I don't like the idea of plastic and exhaust temps. They don't mix well. I also just took a look at the qtec vs the mccord and I just think the qtec is built better in general. They are both good designs, and if you are happy with yours that is all that counts, but from a design standpoint, I think the qtec is a little better.
Old Oct 19, 2003 | 11:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if im not mistaken mccords new one is all metal too.
Old Oct 20, 2003 | 12:24 AM
Engine: 5.7
Exaclty...they are all metal.....I should know..I have one...haha ...not sure where 25th heard they had plastic parts in'em?....but your open to which brand you would like to go with. I found McCord's website first....they had a good price, a good gaurantee, and were very helpful...so...that's why I went with the McCord.....
Old Oct 20, 2003 | 02:34 AM
25THRSS's Avatar
nope, if you look on their website it will even tell you it still has the nylon gears in it. It tries to say that it doesn't matter because it isn't effected by heat, blah, blah , blah. Still doesn't sit well with me. Like I said though, as long as you are happy with yours nothing else matters.
Old Oct 20, 2003 | 10:42 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i just wish someone made a oval elec cutout
Old Oct 20, 2003 | 12:28 PM
25THRSS's Avatar
You could probably make one out of a standard electric cutout. Just bore out the body to the desired shape and get an oval butterfly and it would probably work.
Old Oct 20, 2003 | 12:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
eh, not really
you would have to make a new flange since the width is about 4" and it needs to be shorter anyway... then since you cant just get a oval butterfly, id have to make one.... then get a longer shaft for the butterfly to turn on...
about the only thing i could reuse would be the bearings and the elec motor.
too much work..... if i had a CNC mill, i might attempt it, but right now, i dont have the tools needed to make one.
Old Oct 20, 2003 | 12:45 PM
25THRSS's Avatar
That sucks man.
Old Oct 20, 2003 | 02:53 PM
demonchild's Avatar
why oval???
Old Oct 20, 2003 | 04:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by demonchild
why oval???
well, i want long tubes and i like to drive my car hard on the street.
most guys with longtubes have to go really slow over bumps to keep from scraping the exhaust... the headers themselves are close enough to the wheel that its usually not a issue, but where the exhaust goes after that is..
my plan is to make a y pipe out of oval tube for the best ground clearance... the y pipe will lead into a "catback" in the tranny tunnel...
for my personal amusement and the track, id like to have 2 elec cutouts behind each header.... right now, when i custom make my collector to oval adapter, im going to try to wedge the cutout on at a angle to make it clear nice.... it cant be the lowest point, so its not exactly easy.
if i had a oval one, i could just put it in a oval Y cutout and have the cutout and the clearance.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
middian
Sep 5, 2015 01:42 AM
SlowAZ28
Sep 2, 2015 05:19 AM
bjpotter
Aug 12, 2015 06:06 PM
