to cat, or not to cat...
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
my Trans Am currently has a set of Edelbrock 6872 TES headers/y-pipe, and a Flowmaster American Thunder cat back system. they are currently connected with a single 3" pipe rather than a cat. the car is pretty loud, and i'd like to quiet it up a bit. will there be any significant decrease in hp with adding the cat? i plan on finding the highest flowing cat i can, does anyone know where i might find such a cat?
Car: 83 z28
Engine: L69
Transmission: BW t-5
Look on www.jegs.com or www.summitracing.com. They have hi flo cats. A hi flow cat might quieten up a LITTLE bit, and it won't really affect your horsepower so
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
I have the exact same exhaust setup as you and i had a single 3inch in/out random tech cat. i picked up two tenths in the quarter mile when i cut the cat out. The car feels like it pulls a lot harder without it. those differences were after i put a cam in it, so it might not make much difference with the stock cam.
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Originally posted by BackInBlack86
stock cam? whats that? must be some sort of mythological part, because i've never seen one in my garage.
:hail: i hate people with money! Thread Starter
:hail: i hate people with money! Supreme Member
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Cat Idea
Weld flanges (homade is fine) before and after where the cat would be. Drill the flanges to accept the cat. Now, make a "Direct flow" pipe the same length as the cat with its own flanges. This way, you folks out there who have to pass the "Sniffer" test, can use the cat for inspection, and the straight pipe other times. To reduce sound, use pipe about an inch bigger with reducers on the ends(about 15bux apair). Try fitting up A few diff types, it may help to visit a muffler shop to check out some in-line muffler designs... it's pretty easy, and can be fun changing the sounds
Car: 1990 Camaro
Engine: 355ci
me too! i also happen to hate stock vehicles. and to be honesy, i have seen a stock cam or two in my garage. i saw them right after i removed them and installed a better bumpstick.
some of us cant afford anything new the cost of preventative maintenance is at about my budget list as is.
LT1Formula
Oct 8, 2015 08:34 PM
