Does someone sell long tube headers with the A.I.R. emmissions???
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
I was just wondering where i can get some long tube headers that could pass california's smog test????
Transmission: 4L80E/4L80E
You can't.
If you want long tubes with A.I.R. fittings, give Hooker or Hedman a call. They will probably set them up for you on a special order basis. You need the O2 fitting, too.
They will not have the CARB EO badge on them, though. The company won't stand behind them, and whether the inspector gives them a pass is up to the inspector.
Hooker 2055's would not be a problem. Why do you think you need LTs?
Well doesn't longer tubes mean more horsepower right?? If not then I will get shorties.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
In California I had to go to a "Test Only" station for my 1989 Trans Am. It is the 1 5/8" SLP headers. He wanted to know the CARB number for the headers. I failed until I produced the number. Fortunetely I was able to get it an pass. Allen
Hooker 2055's have the CARB number on a tag welded onto the #1 primary tube.
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
