Do long tubes really make a difference?
Old Dec 6, 2003 | 09:06 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I'm getting ready to put the vortec head kit from Scoggin-Dickey in my 92 z28. I'll be going back in with Comp cam CSXR270HR10. I've already got a set of Hooker Shorty's on my car. Will I benefit anything from a set of long tubes? I've just read so much about problems with the installation of them. The Y-pipe is not an issue because I'll be going back with true duals or a simple H-pipe with some turn downs. Any input will be appreciated.
Old Dec 6, 2003 | 09:12 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
imo, yes its worth it, especially if you want to do duals. and what about problems? i had none installing my hedman longtubes. as for performance longtubes scavenge alot better than shorties and produce higher horsepower numbers
Old Dec 6, 2003 | 10:14 PM
pigsticker's Avatar
Car: 1992 z28
Good info, I just thought it was a pain with long tubes and the starter and oil cooler. What is your hedman long tube part number?
Old Dec 6, 2003 | 11:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Be warned: Vortec heads have a unique plug angle causing MAJOR interference with plug #7 (worse than those with normal straight plug heads). I beat the crap outta my primary tube AND run a shorty plug. The boot still touches, and I mean TOUCHES, the header. I had to put several layers of heat-shield tape around the boot ...and I bet its still gonna eventually burn through.
Old Dec 10, 2003 | 02:20 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Hooker also makes some very nice LT's, but they're about $400.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
