backfiring?
Old Dec 13, 2003 | 12:15 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
backfiring?
Well my exhaust is ok....nothing special since it a LO3. I have stock manifolds, stock y-pipe, 3" intermediate pipe, and 2.5" y-pipe in place of the muffler. (i.e. no muffler) It's nice and loud and all but when I hit higher rpms and just let the rpms drop by themselves it back fires like crazy. it sounds nice and throaty then POP!! It's really annoying and I'd like to know what is causing it. I got under the car the other day and where the guys at the shop welded the y-pipe there are a couple of small holes. Would this cause it, or just the lack of back pressure? I just want to know what to look for so I can fix it. Any suggestions would be nice
Old Dec 13, 2003 | 02:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I don't know if it's true, but I think cool air mixing with hot exhaust gases can cause detonation in the exhaust...
Old Dec 13, 2003 | 03:21 PM
305RSlc's Avatar
so the possibility of cold air being sucked into the exhaust through the holes might be causing the problem? Well I will just weld it back and see if it fixes it, if not then I might have to resort to putting a muffler back on
Old Dec 16, 2003 | 10:20 AM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
Before you go through all that hassle, check your Diverter Valve. and hoses.
Old Dec 16, 2003 | 12:21 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
i have the same problem you either have holes in your exhaust sucking in cold air or youhave low back pressure and are sucking the cold air back through the tailpipe you either have to put a muffler on it , fix the holes, but something on it to create more back pressure, or deal with it
Old Dec 16, 2003 | 10:45 PM
305RSlc's Avatar
excuse my ignoracne, but what is a diverter valve?
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
