Hooker 2055's and Timing
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I've never done a header install before, and was just wondering if after installing the hooker 2055's or any type of header, does the timing have to be advanced or is there any other fine-tuning issues i need to deal with? Thanx.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Depends on the car and what other mods you have. You do not have to touch the timing unless it is still set at 0* from the factory. You don't need any mods to advance it a few degrees. You may need to make some fuel pressure adjustments. Some people run a little lean with headers but most don't. I never did.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I haven't done anything, but mine doesn't run as perfect as I'd like it to. However, I suspect it is the LT1 intake that made the changes in how it runs, not the headers.
Engine: 5.0 TPI
Thanks for the replys guys. Hopefully, all will be ok after i get them installed. I have my mods in my sig....if you want to give any suggestions based on that, that would be cool. We'll see in a couple months what happens.
Car: 92 Z28
Engine: 357 TPI (L98)
It will run great, but there will always be some improvement in prom tuning it, because you're allowing the engine to flow better.
Don't worry about how it will run though, you'll like it.
Engine: 5.0 TPI
It will run great, but there will always be some improvement in prom tuning it, because you're allowing the engine to flow better. Don't worry about how it will run though, you'll like it.
ambainb
Apr 25, 2016 09:21 PM
