What Would Flow Better???
Old Dec 20, 2003 | 04:28 PM
BWW's Avatar
BWW
Simple question, what would flow better-
A. Single 2.5 exhaust without cat
B. Single 3 in exhuast with cat (stock type)
Assuming they both have the same headers and same muffler
what do you guys think?
Old Dec 20, 2003 | 09:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
single 3inch with a high flow cat.. hands down.
Old Dec 20, 2003 | 09:18 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, the 3" single pipe will flow about as much as a pair of 2.25" duals. It's a simple matter of surface area.
THe 2.5" system will offer better ow end torque and the 3" system will breath better at high RPM. Most 3rd gens, even those with a 305 will like the 3" system. In fact some cars had 3" parts from the factory, but these pipes weren't mandrel bent so they are still restrictive.
Old Dec 21, 2003 | 04:15 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
its actually a matter of cross sectional area....which is what you meant i think anyways,
however, the smaller pipe giving better low end torque is a common misconception.....
this can be true, if you have headers/manifolds that are poor at scavenging.......the smaller tube will increase the pulse signal and help scavenging.....but if you use the correct headers to promote good scavenging....you can open up the pipe as big as you want and you can actually pick up some torque due to the excellent scavenging coupled with the increased flow of the larger pipe.
contrary to popular belief, backpressure is never a good thing, its the exhaust pulse scavenging affect that people are after
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
84redta
Sep 19, 2015 09:58 AM
