No cat......any tips?!?!?
Old Jan 4, 2004 | 02:45 AM
killerIROC's Avatar
I have two questions about my 88 IROC 350.
1) If I want to replace my cat with a straight pipe, what steps do I need to take?
And if I decide to leave my cat on......
2) Would it be bad if I left my cat-back disconnected and ran the exhaust out of the cat?
Right now the cat-back is disconnected and it sounds AWESOME!
Any advice?
Old Jan 4, 2004 | 09:26 PM
MdFormula350's Avatar
for 1, just replace the cat with a straight pipe, should be fine wouldnt even worry about the air tube going to it, and it will be fine.
but if u want after that you can go through and delete smog pump and a.i.r tubes on the manifolds.
for 2, no it wouldnt be bad, most people run around with a cutout and thats before the cat(s).
Old Jan 5, 2004 | 12:18 AM
killerIROC's Avatar
So there are no sensors near or inside the cats on thirdgens, because I was told that, I think the person the O2 sensor. And also is the air tube that line that runs into the cat? I guess I just thought that it would be a bigger process. Thanks
Old Jan 5, 2004 | 06:25 PM
Abubaca's Avatar
The 02 sensor is in the manifold, no the cat.
I'm pretty sure you can just block off the AIR tube.
Old Jan 8, 2004 | 10:12 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
my 02 sensor in in the y pipe
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
