single or duel
Old Jan 11, 2004 | 07:46 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
single or duel
what is the most common system on these cars,, i have a good strong 409ci vortec heads ets,,,750 etc,
i am going to the exhaust shop to get prices on a custom system,, this car is right hand drive so a custom system is all i can get,,,,shorty 1 3/4 headers into a 3 inch y pipe then what,,,,,,,,,i dont want a loud system that will drive me nuts driving this thing on freeways,, i just want to get the gasses out and get a beefy note,,,i will use a single 3 inch cat, then what is most common,, single or duel from the cat back,, i want performance most of all ,, not many of these cars here,,,not much to go on,,just this site at this stage
Old Jan 11, 2004 | 10:08 AM
jimmy_mac's Avatar
I never seen one that went from a single y-pipe to duals on a thirdgen. They have either been duals all the way or single all the way. Then of course the muffler on the singles could have dual exits. But by far the most popular is the aftermarket single 3 inch catback. But duals are gaining popularity as more people figure out better ways to make them fit.
Your motor would probably make more HP with a 3.5 inch or bigger system but it seems to be harder to find systems bigger than 3 inches at reasonable prices.
Old Jan 11, 2004 | 11:07 PM
lukerene's Avatar
yeh i recon a single 3 inch wouldn,t be enough,,,,so i think a duel 2.5 inch from ,,whereever i can get would be better
Old Jan 12, 2004 | 08:50 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
duel=
dual=
Old Jan 12, 2004 | 09:22 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
From what i have read if you're throwing out more than 300 hp duals is the way to go. Less and a good 3inch mandrel bent system is fine. I'm assuming since you have the 409 you either already have that 300hp or can get it very very easially. I'd suggest duals, sounds like your car is a good canidate for it. Only question is $
-chuck
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
