Y-pipe isnt fitting up to headers, whats your solutions?
Old Jan 23, 2004 | 04:08 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
hey everyone, i purchased a set of hedman 68481 headers from ACS and it includes the y pipe. The headers are on the car but i cant get the darn y pipe to bolt up. The bolts seem to be too short and the flared end on the y pipe hits the buldge on the end of the header. there is about an inch gap between the bolt holes on the y pipe and header and im not sure how to get this thing to hook up. Has anybody else had a similar problem? What did you do to solve it? thanks for any advice!!
Old Jan 25, 2004 | 08:22 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
That sounds about right to me. As far as I am aware you should have bolts with long shanks and stiff springs that go on the y-pipe side of the flange. The flanges aren't designed to butt together, they should sit apart so that the exhaust has a little flex in it. The springs are to hold the y-pipe and the headers together yet still allow movement.
Old Jan 25, 2004 | 08:37 PM
87Formula4bbl's Avatar
Car: '87 Formula
I wonder why the two sets of headers are different tho? Mine are flanged. So his basically just set in the flanged part of the y-pipe and are held tight by springs right? Seems like youd have a leak, but of course I dont know if there'd be enough pressure inside the system to blow the exhaust backwards out the opening...
Old Feb 3, 2004 | 12:20 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
There should be no leak. Actually I have heard that ball flanges like what you have and I have on my 2055s are the best sealers because they don't require gaskets.
Old Feb 4, 2004 | 09:44 AM
davehamilton's Avatar
Re: Y-pipe isnt fitting up to headers, whats your solutions?
Hey did you gwt your problem solved and get all bolted up?
Old Feb 5, 2004 | 09:35 PM
Car: '87 Formula
Yep, he got it all bolted up fine, just waiting for the cat to arrive and it's finished. I've never seen a hook-up like that (and especially him) so we werent sure, but ya it fits like a charm.
BTW - they look awesome! Wish you woulda been around when I'd ordered my hedmans, think I woulda had the same done by you. Good job!
Old Feb 5, 2004 | 09:56 PM
Thanx alot we try hard to hook you guys up!!!
P.s. new e-mail add- acsheaders@earthlink.net
Old Feb 6, 2004 | 12:31 AM
This doesn't relate to the post....But thanks ACS my 2055s and coated Y look sweet. Can't wait for it to warm up so I can put them on.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
