probably been done, but need opnion:
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
i've been changing my ideas for my exhaust about once a week since i parked her for the winter, well i think i may have found a winner....
currently i have shorty headers "Y"ed into single 3" all the way back, split into dual 2.5" behind the rear end.
my idea:
right where the cat is supposed to be i'm gonna weld in a 3" in/dual 2.5" out 40 series. then i'm gonna run the dual 2.5" pipes out either side right before the rear tires with nice long 3.5" stainless tips. I think it's gonna sound awesome.....
anybody have a sound clip of a similar setup?
hers a Photoshop-mockup
my idea:
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yess, I too have thought of something similar. I thought of putting a single out 40 series on the end of my ypipe then just installing a turn down. Keep us allposted on how it goes if you try it. It looks like it could work and would definatrly sound original.
Engine: 450HP 355
Transmission: TH350
Originally posted by scottland
what do you do when you need to pull your driveshaft or torque arm off?
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
If I were you, I'd have both pipes exit out one side (Like a NASCAR) because I think you will run into clearance issues going under the driveshaft and torque arm with an exhaust pipe.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
not to mention won't this have a melting type effect on the ground effects, or negate ground clearance worse than my true dual setup even, since the tips will come out under the ground effects.
Car: 1984 Z28
nope guess not....but they'll still exit out pretty low to the ground don't you think? asuming a one inch gap between the body and the tips at least, plus 3inch tips....that's 4inches lower Thread Starter
Engine: 450HP 355
Transmission: TH350
i have the *** jacked way up so when i hold a 3.5" tip about 1/2" down from the exit point i still have a good 6" of clearance to the ground.
i do have the factory little plastic half-accents right before the rear tires, with about 1/2 inch of clearance and a decent set of tips i don't think melting would be a problem, or atleast hopefully not......
