what cat do i need?
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
what cat do i need?
ok got system with a 2.75 intermediate pipe, its got a flange where it bolts to the cat, what cat do i need to use? like how big and all that stuff
Transmission: 4L80E/4L80E
Do you have factory cast iron exhaust manifolds or headers?
Are you willing to upgrade to headers?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
2.75' is a goofy size and you won't find many cats out there in that size. Your best bet is match your cat size to a y-pipe size on the headers of your choice and then fab it up from there.
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
5.7 yeah i'm going to do shorty headers with y-pipe (probably hedman)
also could i just cut the flange off and make it like a normal slip on?
Get the headers/y-pipe for the '86-'90 TPI single cat application. Then get the direct-fit cat CTO-9118 from Summit. Modify your cat-back to fit the cat (unless you go ahead and get a proper cat-back as well).
LT1Formula
Oct 8, 2015 08:34 PM
