Positioning of oxygen sensor bungs for Hooker Long Tube 2210's?
Old Feb 27, 2004 | 08:33 AM
Dr G's Avatar
Guys,
I am thinking of getting a set of coated 2210's for my car.
My question is:- Where should I ask for the oxygen snsor bungs to be placed? Prior to coating of course! I need one on each header, for the standard O2 for the car and also a separate one for a wideband sensor for datalogging.
In his article Traxion suggests that there was more space on the driver's side top of the collector - not the side. What about on the passenger side header? Your thoughts and ideas would be much appreciated.
Gordon
Old Feb 29, 2004 | 12:32 PM
Dr G's Avatar
TTT Anyone got any ideas?
Old Feb 29, 2004 | 10:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From https://www.thirdgen.org/techbb2/sho...5&pagenumber=1 :
"12) You have 2 options with regard to the oxygen sensor. If you are getting a Mufflex Y-pipe then you can order it with O2 sensor bungs. Problem solved. If you have a custom Y-pipe or if you want to put it in the header then the oxygen sensor bung should go on the driver's side TOP of the collector - not the side. There’s more clearance on the top. Get it welded in before you get the headers coated. Definitely consider using a heated O2 sensor. Part numbers and info on this can be found by using the search. I’m using a ’92 Corvette ZR1 heated O2 (bosch 13077). Click HERE to see how the O2 sensor is installed."
See the original post for the embedded link.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
anesthes
42
Oct 24, 2015 07:30 PM
formula_novice
Sep 5, 2015 03:58 AM
beast94
Aug 20, 2015 06:44 AM
