Anyone with a 305 TBI please enter...
Old Feb 28, 2004 | 11:10 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I have a stock 305 TBI and it needs exhaust bad! The Cat is shot and so is the rest of the system beyond the cat. My delima has to do with the size of the cat and cat-back I will be getting. I am either going to get the Flowmaster American Thunder 3" system (part# 17233), or the 2 1/2" intermediate system (part# 17234). I don't know whether to get a 3" cat through the 3" cat-back, or the 2 1/2" cat through the 2 1/2" cat-back. For now, I am keeping the manifolds and stock y-pipe. I know the LO3 looses low-end torque (the only good aspect of the engine) from headers w/3" system all the way back. I want the loud powerful sound of the 3" but not the loss of low-end torque. Now, who has this system? What do you guys recommend? Thanks.
Old Feb 28, 2004 | 11:51 PM
CorVM's Avatar
Car: '92 Pontiac Firebird
Engine: LO3 305ci.
I've got a 3" Flowmaster American Thunder, and I love it. It sounds great, and is quite loud. Probably helps some that I don't have a cat though. I've heard that you lose some power with that big of exhaust on the 305, but it seemed like it had a little bit more get-up-and-go the 1st time I drove it, but it wasn't that much.
Old Feb 29, 2004 | 01:53 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I lost some low end after putting on headers with my 3 in exhaust. With just the manifolds it was ok though. Just my 2 cents
Old Mar 1, 2004 | 05:15 PM
3rdgenstm's Avatar
Car: ‘92 Z28
I just put on a Dynomax cat and catback. It does honestly feel a lot better over the stock crap that was on it. I bought the cat and cat back from Jegs for $260. I thought of Flowmaster, but everyone has it and I think it just sounds a little rednecky-- for me.
The Dynomax pipe dia is 2 1/2" (intermediate and tailpipes) compared to the 2 1/4" that was on my car. The 2 1/2 is big enough for the L03; you should gain a little low end power with it. I too retained the stock manifolds and y pipe (although I am looking a new y). My L03 is bored .030"+, so I have a tiny bit more power to start with.
The cat I bought is a direct fit 'hi flow'. It flows over 30% better than a stock one.
The muffler flows 260 cfm, I think, compared to the 150 cfm of a stock. It's not super loud, but it does have a nice low rumble to it at idle and a nice 'rasp' when you rev it to about 3500 RPMS. I am pleased with the system so far.
I made a post in the exhaust forum on some install tips.
Hope this helps.
Old Mar 1, 2004 | 06:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would keep the stock cat for now and just get any 3" exhaust system built for TBI cars. That way it will have the necessary reducer on it to attach to your stock cat. When you go with headers, it will be much easier to match diameters with less fab work. That is what I did. Now if you were replacing the enitre system, I would recomend getting a system from headers back for a 350TPI car. That way there wouldn't be any reducers and it would all be 3". You will not lose any low end power at all with a 3". You will make more power at every RPM point in the band. it may feel like you have lost power but that is just because of the power gain you feel up top. Get a 3" system and don't look back.
Old Mar 1, 2004 | 06:28 PM
Car: 89 RS
Hmmmm.. Thanks for those encouraging words Shifty. Now that you say that, it makes sense cause I did gain upper end power & that would explain the difference of feeling off the line. Thanks, you made a believer out of me
Old Mar 1, 2004 | 06:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea it is wierd because your power band just widens a bit. For the same reason why people think LS1's have no low end. They are just blinded by its monsterous high end. But if you look at a dyno power curve you will see that the low end is very much there and much better than stock.
Old Mar 1, 2004 | 08:59 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Re: Anyone with a 305 TBI please enter...
most people gain 20-30 rwhp from a header swap. IIRC they actually gain torque too. headers are a very good thing on our cars, im workin on getting mine in right now, boy what a b!tch.
Old Mar 2, 2004 | 09:05 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
Dynomax headers, 2 1/2 y-pipe into cut out (placed where cat used to be) and finally a 3" edelbrock cat back
the difference for stock is definitely noticealbe,
loss of low end is BS, I'm not affraid to run any LO3s around my area
Old Mar 2, 2004 | 10:43 AM
Kleen RS's Avatar
Car: 92 25th Anniversary RS
Engine: A slow one. The infamous 305 TBI
Transmission: 700 R4
I am glad this was posted, because this was my question. I am hereing things that go both ways.
I am running a stock LO3 and I plan on deleting the cat and just running a straight pipe from the Y back to the muffler. Are you guys saying to run 3 inch with a deleted cat or 2.5?
When the muffler fell off I lost some low end. I want it back dammit.
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
