View Poll Results: What exhaust set-up for Spohn Torque arm etc?
Be brave and get the 2210's, run true duals and then post the pics!
63.64%
Run SLP shorties and then Y-pipe into stock route exhaust system.
36.36%
Voters: 11. You may not vote on this poll
Spohn TA etc, go for Hooker LongTubes with true duals, or SLP shorties into Y-pipe?
Old Mar 5, 2004 | 09:04 AM
The Doc's Avatar
Okay, what do you guys think? If someone is getting a Spohn 301 Torque arm with new transmission cross member should:-
1. Be brave and run Hooker 2210 Long Tubes and fabricate a true dual set-up (perhaps with oval pipes)? Do you think you'd need to notch the frame rails?
2. Be scared!, and run SLP Shorty headers into a Y-pipe and stock routed exhaust?
Your comments are most welcome.
Old Mar 5, 2004 | 10:21 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
What is the rest of your setup?
Old Mar 5, 2004 | 10:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what do you plan to do with the car?
if its a nice day weekend cruiser, the answer is diffrent then a driven 3 days a week to work fun car.....
Old Mar 5, 2004 | 11:04 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Decisions, decisions...
I have been thinking along the same lines, and here is what I have settled on:
Install the Torque arm, subframe connectors, etc, and then decide on if you will have room. If you put in either exhaust first, you might regret it.
I would be willing to do some minor hacking to get the Long Tubes in, but not to re-engineer the whole bottom of the car. If you have to make too many wild twists and turns in the exhaust to clear the undercarrige, you will be more likely to have ground clearance problems and that defeats the purpose of the Long tubes in the end.
Just my 2 cents...
Troy
So Cal
Old Mar 5, 2004 | 11:55 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i will be doing the first of the two, ill post pics whenever everything gets done
Old Mar 6, 2004 | 12:24 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I will be running hooker long tubes with a dual system with cutouts x-pipe and dumps before the rear axle. If I go round pipe I'll run chambered bullets. If I go oval I'll run spintech cruzer series mufflers while maintaining ground clearance no lower than at the header collector or alston SFC's..
I have both spohn and alston/TDS subframe connectors, a T56, and a Global West TracLink torque arm, and 3" LS1 driveshaft.......so space is limited. I'd prefer round pipe for cost and because other people will be able to duplicate it easier if they want to go the same route, but I'll go with whatever gives me the most clearance. I will post pics when I'm done.
Old Mar 9, 2004 | 05:53 PM
The Doc's Avatar
The car is a weekend street warrior and occasional strip and autocross car.
The thinking is to install all Spohn suspension/chassis parts, both Spohn and Alston SFC's and then work the exhaust around whatever space is left!
Drain89 and KagA152 be sure to post some pics once you are done!
Any more input guys?
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
Chevykid810
Sep 28, 2015 12:57 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
