How to tighten header not pass/ side by firewall
Old Mar 7, 2004 | 08:47 PM
86IROCZ4u2nv's Avatar
Car: Black,,1986 IROC-Z
Engine: CARBED 305c.i.
Transmission: 5 speed, T-5
Hey all thanks for looking, I have a question, i just put in T.E.S Edelbrock headers and i cant get to the last one on the passenger side by the fire wall to tighten all the way. What do people typically do to tighten this. thanks in advance for any help Dan-
Old Mar 7, 2004 | 11:33 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
jack up the motor i think, not quite that far on my install yet though to know for sure.
-chuck
Old Mar 8, 2004 | 11:43 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Use a box wrench and get it from underneith. It helps to have the car jacked and have the pasenger side wheel off so that you can crawl in from that spot.
Old Mar 8, 2004 | 11:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
how to access your headers and spark plugs in 3 easy steps:
step1: pull the engine mount bolt on that side...
step2: place wide piece of wood that covers the entire oil pan stump on jack under motor... jack motor up.
step3: place a piece of wood or steel between the motor mount and the motor. set the engine on it.
you now have the motor tilted for easy easy easy access.
i have a 3" long piece of square tubing i use instead of wood, but most people dont have that hanging around.
Old Mar 8, 2004 | 02:29 PM
Marc 85Z28's Avatar
That bolt would always loosen on me after a couple of week of driving, no matter what I did with it. How did I tighten it? I got a small box wrench, only about 5" long, and tightened it 1/12 a turn at a time from the top. Its a tight fit, but it can be done. I got so good at it I could do it in the dark without seeing the bolt...
Old Mar 8, 2004 | 06:36 PM
thanks
thanks for the feedback all. I ll try the wrench idea i dont want to play with the motor mounts thanks again Dan-
Andrew6.688
Dec 13, 2015 10:59 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
