Second Gen Headers
Old Mar 11, 2004 | 08:02 PM
vampiroc's Avatar
Car: Z28
Second Gen Headers
Anyone running second gen style long tubes with a bit of modification?
Old Mar 11, 2004 | 10:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I think I read on here somewere that a set made by Hooker for 2ndgen Camaros will fit 3rdgens as well, but don't take my word for it.
Old Mar 18, 2004 | 03:23 AM
vampiroc's Avatar
Car: Z28
lol, hedman said the headers I bought would fit perfectly for an 85-92 f-body, and they needed some work. you have a part number? I figure if I have to modify, might as well get those big *** 1 3/4" long tubes available for cheap for second gens.
Old Mar 31, 2004 | 08:47 AM
AFTERMIDNIGHT's Avatar
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
i put mine on and the only clearence issues i had was the collectors hit the frame rails, i cut and angled the collector in a bit, then the other clearence issue was the #8 cylinder, back passenger, primary was hitting the firewall right below the heater box, i cut the corner off the firewall and fabbed a new one in it's place. my car has solid motor mounts in it so fitment with stock mounts may be different. the BIGGEST clearence issue was the collectors, but like i said, cut a "V" shape in them, bend them in a little, then weld them back up.(i got a little more than 3/4" more ground clearence doing this)
AussiePr0nCar
Mar 6, 2020 04:04 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
