air management ?
Car: 92 25th Anniversary RS
Engine: A slow one. The infamous 305 TBI
Transmission: 700 R4
air management ?
Alright, I took the car to the muffler shop today to get an estimate. While I was under the car looking at it I noticed an air management tube coming from my cat. Well, I am wanting to delete the cat. What should I do with the air management tube? I hear that if you plug it then that will back up into the smog. Whats the story here, what should I do?
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Well, if you remove the catalytic converter, there is little point to retaining the AIR system (since it is meant to improve converter efficiency).. Might as well remove the smog pump and air tubes...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Kleen RS
where should I find the SMOG delete stuff? And, taking this off won't throw any codes or anything will it?
