Manifold Question
Old Mar 21, 2004 | 06:52 AM
Pat Hall's Avatar
Manifold Question
I have a set of exhaust manifolds with the 3 inch y-pipe and cat from a 5.7 tpi car. Right now on the car I have the stock 5.0 tbi manifolds and y-pipe. I can definitely see the difference in size comparing the y-pipes to each other, but at a glance the exhaust manifolds look like they have the same size collector flanges. Is there a difference between the collector sizes on the two different manifolds or is just the y-pipe that's bigger in size???
Old Mar 21, 2004 | 06:35 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Manifold Question
I am pretty sure the L98 stuff is bigger all the way around. I know the ypipe is bigger and so are the primaries. I am not sure about the collector. Both may be 2". I will measure mine tomm.
Old Mar 23, 2004 | 06:40 AM
Pat Hall's Avatar
Thanks for the response Shifty. I guess I could look at mine too, but I just barely put the y-pipe back in about a week ago and really don't want to drop it all over again just to compare collector sizes! I'm mainly interested in the difference so I can maybe get out of having to change the manifolds along with the y-pipe. Y-pipe changeover=15 minutes, changing manifolds=lots of swear words and who knows how much time. BTW I noticed you're in the Dayton area. You can give my old man a kick in the ***. He lives in Beavercreek.
anesthes
42
Oct 24, 2015 07:30 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
